Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (DirtTaxi, 1955 1 Series, 50Chevy3100, TooMany2count, Leo, 2 invisible), 564 guests, and 1 robot.
Topics126,781
Posts1,039,297
Members48,100
Most Online2,175
Jul 21st, 2025
#894363 11/04/2012 10:54 AM
A couple of my lifters in my ol 235' seem to be a little loose so I have the valve cover off to set them. Looking through some of the tech tips I used originally when I rebuilt and set the lifters,really ran smoothe. Now with #1 in Top dead center bothe valves shut I notice you can push down the intake lifter but not the exhaust, could this be a bad lifter I am looking for, myself I wouldn't think you could push them down at all after it's been running for about 3 years. Thank you..
You could have something caught in that lifter check valve, you should not be able to push down on a lifter that is full of oil.
A lifter that has air trapped in it can also do the same thing.
You may want to look at my blog. I have a topic there about getting trapped air out of 235 lifters. My blog link
My Blog
Hey there'68 Dave cool Blog I'll check it out, I didn't think you should be able to push down on a lifter like that eighter,Thank you..
Hi dave, I used your waterpump adapter plate on my rebuild, turned out great. My 1956 engine with new cam and hydro lifters takes about 4 minutes to quiet down at idle. This happens every time I start it up. The machinst told me to run the adjuster screw down only one turn after taking the play out of the pushrod. Shoul I take it down the 1 1/2 turns the manual says. I dont remember if the pushrods have that slot in them. He told me not to soak them either. Them motor has about 4 hours on it. The body is still in the body shop. Thanks Dave
Tony
I would set them at one and one half turns.
Hydraulic lifters that are noisy on start up usually have a little to tight of clearance between the plunger and the body of the lifter. Once the lifter starts to warm the expansion of the body releases the plunger and the lifter will then function correctly. This problem will most likely go away with use.
Good luck with your project.
And thanks for using my water pump adapter.
My Blog
I had a similar problem. I would up slotting the ends of the pushrods per Pre '68 Dave's suggestion. They are working fine.
I too also used one of Dave's water pump adapters on my 58-62 block using my original set up from my 1950 3600. It too is doing well.
We better quit talking about things like this or murphys law will engauge!
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Thanks for the reply Dave, I will let things just roll along and have a good time.
Tony
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.144s Queries: 14 (0.075s) Memory: 0.6189 MB (Peak: 0.6746 MB) Data Comp: Zlib Server Time: 2025-09-22 21:12:46 UTC
Valid HTML 5 and Valid CSS
