| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | I rebuilt a 216 Chevy motor & installed new pistons/rings & solid lifters. I think the old pistons were 30 thousands oversize; the new ones were 40 thd's over. Are the old pistons & lifters worth selling or are they only good for the srap metal shop? I have the same question for the old low-pressure oil pump. Thanks. | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Somebody can use it! They don't make them anymore,but being a 216 somebody that wants to put it in a truck that had a 216 in it would want it. Don't scrap it out! http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | Unless the lifters are badly damaged or rust-pitted, the bottoms of them can be reground and reused. There's supposed to be a slight radius, not a flat bottom or a cup shape. Pistons- - - -also reusable if they're not cracked or the ring grooves aren't worn. There are lots of used parts for sale on Ebay- - -it might be worth a try, or list them here at the "swap meet" forum.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Somebody can use it! They don't make them anymore,but being a 216 somebody that wants to put it in a truck that had a 216 in it would want it. Don't scrap it out! He's just talking about the piston rings and lifters. Your post seems like it's referring to the entire engine. | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | O , I see now! Me bad, LOL..... Do as Jerry said. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
