| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | Can 2" or 3" lowering blocks be used on a stock 50 rearend suspension with the torque tube still in use? My main concern is the geometry with the old style U-joints, etc.....
Another rodder told me he had trouble with a open drive line hitting his center cross member while using the 3" blocks; however, he has an open drive line so the U-jopint issue was less of a problem. | | |
#8947 05/18/2004 11:31 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There will be no ujoint issue with a torque tube rearend because there is only one, and you will be decreasing the angle. As long as it doesn't hit anything you will be fine. You may want to check that the splines on the front end of the torque tube are clean enough, though, or it may not retract enough when you hit a bump and you may bend something.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | Thanks for the reply. The whole drivetrain is rebuilt but I haven't had the whole truck together to drive yet. Does the bell at the trans abd driveline hook up have to be loosened before installing the lowering blocks> I would guess it does. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | No, it shouldn't need to be, it should pivot freely.
