1 members (ShopRag),
170
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | The endplate on my 52 generator was broken at the mounting ear.
This gen is a stock Delco 6v. The endplate is aluminum or pot metal, with a small "Delco" on outside and a "7" on the inside.
Can you get gen. endplates for 52 or which others interchange? I see some NOS on epay, but they all look different.
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | You should have Delco unit number 1102742 or 1102749 Both took the standard cast aluminum 2 brush end plate that was used from around 1942 and up. I scrolled through ebay and didnt see what your needing. I may have a couple of NOS ones left. I will check this afternoon and let you know. | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | I still have some NOS Delco 1913990 end plates. I will email you a photo. Ken
