1 members (WingWright), 103 guests, and 1 robot.
Topics128,049
Posts1,055,680
#893350 10/30/2012 6:55 PM
how do you fix a exhaust a leak on the manifold,, i just rebuilt the motor and when putting the intake and manifold togther i did a small gap i i sanded the intake a little and used 2 gaskets on the exhaust side ,, do you think onces it gets hot i could retighen the bolts would help ???
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #893482 10/31/2012 7:48 AM
You might try and loosen the 4 bolts that hold the intake and exhaust manifold together, then try to realign the manifolds to the head and tighten them. Then tighten up the 4 bolts that hold the 2 together.
lilrobo #893490 10/31/2012 8:58 AM
I've never heard of using 2 gaskets? If it is not sealing, something is not aligned or maybe a small crack? I agree with Don about losing up the intake/exhaust to get a good alighment. Did you check the flatness after you sanded it?
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
lilrobo #893503 10/31/2012 9:45 AM
I tried tgat befor i even elongated the 4 holes and tried that, ,some people told me that they worp in time, it was fine before i removed them. I will try to realign them after i get it running better,, the intake is pulling up good, you can see it mashing in, so got me ,i will loosen them and try again
Thanks guys
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #893521 10/31/2012 10:43 AM
Was the manifold cold when it was removed? If not, this could be why it won't fit now. If it was cold, there must be something out of alignment.
My 46 GMC on Photobucket
46gmcpu #893541 10/31/2012 12:11 PM
yeah i say it cold ,, would it help if i let it get hot and try to retighten ??
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #893686 11/01/2012 10:34 AM
No, if the manifold is not completely cold when removed it's more likely to warp. Getting it hot and then trying to tighten it probably won't help your situation. If it's not sealed when cold it won't do any better when hot.
lilrobo #893701 11/01/2012 11:39 AM
try a local machine shop
I had the same problem with a exhaust leak at the manifold.
I believe he charged me around 60 bucks.
lilrobo #893711 11/01/2012 12:14 PM
dads50 what did they do mill both to match ,, have to be careful about the rings in intake ?
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #893736 11/01/2012 1:45 PM
My exhaust was leaking at the 2 inner ports
...pic...
...pic...
I took it to him and he put a straight edge on the manifold.
you could see where the outer edges were hitting first.
he endeded up milling it and I believe he took off less than .020 before it trued
this is what it looked like when he finished.
...pic...
nothing had to be taked off the intake.
If your worried about your alignment rings you can take those down with a file.
I had to call three shops before I found someone willing to mess with it.
lilrobo #893966 11/02/2012 12:58 PM
right now my intake is hitting first ,, so it dont need to be ground ,, the intake does ,, i took a large belt sander to it and did a little , i marked the rings to see how har i could go ,, i was scared to do too much ,, i belive i could do more i could do the rings a little also if needed ,, i might get back to it after i get the motor lined out
thanks for the info
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #893972 11/02/2012 1:28 PM
The part that makes first contact usually is what needs to be taken down to the same plane as the others.
lilrobo #894072 11/02/2012 10:15 PM
I got to through some of things right now i will address that later i need to get running good and and set the timming get the motor seated in first, , but i will take it off and sand a little more
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
