8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86),
114
0
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | hey guys i hope i ant doing something wrong here,, i pulled my motor and had it rebuild and forgot to install the tranny lines then and had to it afterwards,, that was no problem, , when i got them in i found a couple pin holes, , a buddy of mine told me to just run rubber lines, ,so i got rubber tranny lines and got the right barrbed fittings ,,,, i hope i ant makeing a mistake, ,i can run them nice and neat and tuck them away ,,, what do you all think?..
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | What transmission are to working with? If an automatic why can't you make and run new steel lines?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Yeah powerglide i could try to run the steel lines throug there, but they zre ment to be run before the motor is installed,, i got mine in with a little bending , i was thnking this would be a lot easyer, they are tranny lines not fuel lines so should be ok no?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lilrobo, If the hose you are using is rated for flowing hot transmission fluid at approximately 50 p.s.i., them you should be okay. Do not tie the hose so tightly that it can't move when the engine/tranny does. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Thought about running through the frame rail a little, , and yes they are made for tranhy use cost a little more than fuel line butt thats ok Thanks forall the help guys
