2 members (Tronman, KEVINSKI), 197 guests, and 3 robots.
Topics128,257
Posts1,058,017
Members48,479
#889630 10/15/2012 7:55 PM
1 Offline
I just installed a new gas gauge, sending unit, and tank in my 1953 3100. Its a 12V system. The gauge does not work as it doesn't move from empty. I want to confirm how the gauge is wired. What side of the gauge does the sending unit ground hook up to and what side does the ignition? I thought my gauge had a positive and negative on the back but I'm not sure since I can't see it without taking it back out. Thanks for your help.
1953 3100 Chevy 5 window
1971 Chevelle SS
...pic...
Sometimes the new gauge needle will pinch on the bezel. Check to see it is clear.
...pic...
Also make sure the gauge itself is grounded to the housing
...pic...
1 Offline
Yes, before I installed I made sure the needle was clear and removed the paint for a good a good ground. I'm thinking maybe I wired the gauge wrong between the ground and the ignition. Is that possible?
1971 Chevelle SS
On my truck the sender grounds to the bottom of the cab
...pic...
...pic...
Not sure if it's the same on your year
Sir Searchalot
Sir Searchalot
The gauge will have an ignition terminal (switched 12V) and a sender terminal and I believe is grounded by the case/mounting. The sender should be also grounded from one of it's mounting screws to the frame. This is a must have wire, otherwise you are relying on straps, tubing or touching, not good. Wire brush the sender flange, screw and a nearby spot on the frame, install the wire and then cover all the bare spots with that liquid insulator. Be sure the frame is grounded to the body and body to engine. It all should be checked for operation before final installation. The same careful grounding should be done at the gauge(s).
If you have a simple test probe with a light you can test the power side of the guage and make sure you have power. If you then touch the sending unit side of the guage the guage should move. I know it's difficult to get to while standing on your head under the dash so you can do the same by probing the wires that connect to the guage.
You can also test the fuel sending unit with an ohm meter. It should read between 0 and 30 ohms.
1 Offline
ok, thanks, I'll give it a try
1971 Chevelle SS
There is great help on this in Tech Tips.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
1 Offline
Ok, I pulled the gauge and the problem was that it wasn't grounded properly. With the sending unit out of the tank, I moved the arm up and down and the gauge worked properly. However, once I mounted it to the tank it would not work. The needle stayed on empty when the tank was 3/4 of the way full. Is this a bad sending unit or do I need to try bending the arm? This is strange it would work properly out of the tank but not when its inside of the tank.
1971 Chevelle SS
Hi, 53, It sounds like you have the float arm indexed wrong. If you have the in cab fuel tank you should have the float arm facing the side of the truck. If it is facing the back or front it will hit the tank and not move. If it is like a boat sender you can unbolt the center bolt , lower the sender and rotate 90deg and then bolt it up. Hope this helps. Have fun, Brian
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
Does the float float? You could ohm your sensor to ground to be sure the ground is good.
1 Offline
Thanks Brian, yes, I made sure the arm was facing the drivers side of the cab. I also did a test in a bucket of water and it worked fine. As I mentioned, it worked fine when its connected outside of the tank which tells me it has to be something in the tank. I believe these are 19 gallon tanks so maybe I just don't have enough gas in the tank. Its about half full right now.
1971 Chevelle SS
Hi, 53, Check the length of the sender float to the mounting flange out of the tank in the empty position and with the sender out of the fuel tank, check how deep the tank is. You may have the wrong sender. You want about 1/2" clearance of the float above the bottom of the tank at empty.
