1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Got new single master cldr from Napa installed it leaked at both ends,took it back got another one its leaking at rear crush washer too. Ive tried to tighten but it wont tighten. I cant believe having same problem with two new cldrs. Suggestions please? | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Sometimes no help is the best help. I finally stopped the leaks found new leak at wheel chord got that. Finally got help bleeding lines to coin ole Willie On the road again! | | |
