5 members (rfs56trk, Gdads51, 2-Ton, 78buckshot, 1 invisible), 180 guests, and 4 robots.
Topics128,078
Posts1,056,024
Members48,433
#89366 02/14/2002 4:44 PM
V
V Offline
Hello from Mike ,
I have noticed quite a few posts on the 6 to 12V conversion topic . Things like fuel guages are a problem with a easy solution . Electronics supply Places like Radio Shack sell simple solid state voltage regulators for a couple of bucks . A 7806 1 amp 6V regulator will provide a 6v source for a original 6v gauge and sender unit . Just wire in the 7806 between the 12V source ( ignition switch ) and the gauge HOT terminal post . Ask them for a diagram of the 7806 and away you go . It's simple to wire in , only 3 connections .
5 amp 6V regulators are also easy to buy , these can run original 6V wiper motors from a 12V source ??
Because 6V is being dropped some heat is generated so be aware that a heat sink may be needed in some cases.
Bye from Mike
1940 Canadian Chevrolet Series 13 (1/2-t) utility (Australian)
Lots of history here!
Read ot all in the DITY
#89367 02/14/2002 5:29 PM
For those of us who have had the experience of doing this a couple hundred times in our life It ends up not being quite that simple. The Radio Shack reducers will work in some cases but only if the voltage and load both remain constant which in our case is seldom. I spent the past ten years working this out and tried everything available from Radio Shack and all the aftermarket and nothing was reliable 100 percent of the time.
In the case of the Radio Shack products they typically had a 6 month life span. Accuracy was also a problem on certain applications...
That is why I designed the Runtz for the dash gauges, they will accept an incoming voltage range of between 8 and 20 volts and put out a constant 7.5 volts. They are solid state for accuracy, and also have built-in circuit overload protection to protect the dash gauges from excessive amperage such as in the case of a short in a wiring harness. They also come with a 2-year warranty. There is more things to consider but the point is you get what you pay for. :rolleyes: eek eek
