4 members (Nick in Manitou, TUTS 59, Alaska54, Cosmo), 54 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#89342 09/08/2003 11:59 PM
Got in the 52 to go to work this morning,batterlow would not start, I did not leave anything on this time, at least I saw no signs of it,,,the battery's are good , and put on a new alternator last week, no problem till this morning, drove the truck yesterday with no problem, what would cause a drain,, what is the best way to look for a short? I put in my other fresh battery, truck cranked right away,,guess tomorrow will tell me something,,,,Fred
Redryder pix
My Hotrod
#89343 09/09/2003 12:45 AM
Disconnect one thing at a time until the drain goes away. Taking off one of the battery cables and jumping across to the battery with a bulb is a good test setup. I would suspect your new alternator has a bad diode or regulator.
Paint & Body Shop moderator
#89344 09/09/2003 1:55 AM
are you sure that the new alt. is charging?
Just a thought
Brian K
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#89345 09/09/2003 2:19 AM
Brian. it is according to the trucks gage,when you turn on the headlight switch you can see the amp gage charge a little more, I will wait and see and then take the new alt off and get it checked, but all looks normal, something is weird though cause the battery was a 850 cca and it went down over night, the battery is only 3 months old...Fred
Redryder pix
My Hotrod
#89346 09/09/2003 12:11 PM
Fred - you sure that your brake lights are not hanging up? I know that's a little obvious but pulling down a 850 cca battery over night is a pretty good draw. Radio?
Like suggested, start with a circuit tester and check each item one by one.
#89347 09/09/2003 3:10 PM
Fred: My 88 GMC kept doing that would show just a little charge but not enough to keep battery charged. Had every specialist look at it check it; tried 3 different 100 AMP alt. Finnally I said the heck with it and took the wire that went to firewall and hooked it directly to battery.
No more problems!! I'm happy popcorn The Truth is Out There (Good luck keep us posted)
#89348 09/10/2003 6:31 PM
Joker have you checked for a short?
#89349 09/11/2003 2:43 AM
checked the new alt that I bouught last week, it is not chargeing right, trying to install the new one tonight, got dark and had to stop. having trouble getting the fan belt to line up straight,,these after market things can be a pain in the a,,. had no problem before and it is suspose to be the same alt,,,will try again tomorrow,,thanks for all that have responded,,,Fred
Redryder pix
My Hotrod
