| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89342 09/08/2003 11:59 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Got in the 52 to go to work this morning,batterlow would not start, I did not leave anything on this time, at least I saw no signs of it,,,the battery's are good , and put on a new alternator last week, no problem till this morning, drove the truck yesterday with no problem, what would cause a drain,, what is the best way to look for a short? I put in my other fresh battery, truck cranked right away,,guess tomorrow will tell me something,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#89343 09/09/2003 12:45 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Disconnect one thing at a time until the drain goes away. Taking off one of the battery cables and jumping across to the battery with a bulb is a good test setup. I would suspect your new alternator has a bad diode or regulator.
#89344 09/09/2003 1:55 AM | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | are you sure that the new alt. is charging?
Just a thought
Brian K
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#89345 09/09/2003 2:19 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Brian. it is according to the trucks gage,when you turn on the headlight switch you can see the amp gage charge a little more, I will wait and see and then take the new alt off and get it checked, but all looks normal, something is weird though cause the battery was a 850 cca and it went down over night, the battery is only 3 months old...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#89346 09/09/2003 12:11 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Fred - you sure that your brake lights are not hanging up? I know that's a little obvious but pulling down a 850 cca battery over night is a pretty good draw. Radio?
Like suggested, start with a circuit tester and check each item one by one. | | |
#89347 09/09/2003 3:10 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Fred: My 88 GMC kept doing that would show just a little charge but not enough to keep battery charged. Had every specialist look at it check it; tried 3 different 100 AMP alt. Finnally I said the heck with it and took the wire that went to firewall and hooked it directly to battery. No more problems!! I'm happy popcorn The Truth is Out There (Good luck keep us posted) | | |
#89348 09/10/2003 6:31 PM | Joined: Mar 2003 Posts: 17 Member | | Member Joined: Mar 2003 Posts: 17 | Joker have you checked for a short? | | |
#89349 09/11/2003 2:43 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | checked the new alt that I bouught last week, it is not chargeing right, trying to install the new one tonight, got dark and had to stop. having trouble getting the fan belt to line up straight,,these after market things can be a pain in the a,,. had no problem before and it is suspose to be the same alt,,,will try again tomorrow,,thanks for all that have responded,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
