0 members (),
136
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Is adding a '55 or later engine, transmission, driveshaft and rear to a '51 GMC 1/2 ton a fairly simple operation?
Thanks! Dickson
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What engine and transmission?
Most likely you will be changing to an open driveshaft, so you will have to make or find a driveshaft that is the correct length.
| | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | I didn't know the gmc was longer but that's good right? would he still need a short pump?.
I guess you have to fab a plate and a shroud
Here is a shot from Mike Stark's Webshots page who installed a 261 in a GMC truck. This plate he made will work for your application as well.
GMC Adaptor
link courtesy of stovebolt user SWEET
| | | | | Joined: Oct 2012 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 62 | Thanks guys. Looks like a GMC 302 might be a better option. We'll see.
I can weld and fabricate, so a couple of custom brackets would not a be a huge deal.
1950 Chevy 3100 short bed 1951 GMC 3/4 ton long bed | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Were you originally thinking a V8 or I6? That makes a big difference... | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Going from 228 gmc to 302 gmc is a fairly staight forward swap.
Some monkey wrenches to lookout for would be in the flywheels. A 228 will have a 4 bolt 6 volt flywheel. All 302 gmc engines have 6 bolt flywheels. Since 302s came out of either military vehicles or big trucks, the flywheels will likely be unsuitable for a 1/2 ton truck. The 6 bolt 6 volt flywheels from a 54-55 248 will work on a 302 and can be used with the original 6 volt stomp starter and 51 gmc bellhousing. Those flywheels are often hard to come by. The 56-59 270 gmc 6 bolt 12 volt flywheels are often easier to obtain. The 12 volt flywheel needs a 12 volt starter.
139 teeth = 6 volt flywheel. 168 teeth = 12 volt flywheel.
Next monkeywrench has to do with the front timing plate. Later civillian 302 motors used a different front motor mount. To bolt one of these civillian 302 motors in pre 1955.1 truck requires swapping out the front timing plate. The swap isn't hard but requires significant dissassembly of the motor. Here's a list of what needs to be removed to swap the timing plate.
Valve cover Rocker assembly Side Cover Push rods Lifters Distributor Fuel pump Oil Pan Harmonic Ballancer Timing cover Camshaft Now you can get to the timing plate
Military 302 motors have their own unique challenges when installing in a civillian chassis. I haven't done a military 302 swap, so I am not versed in those challenges. More info can be found on the oldgmctrucks.com forum.
Next monkeywrench will be in the open drive rear end. Some welding will be required... unless you can find a 1955.1 rear axle and springs. The 1955.1 axle and springs will bolt into your truck and give you an open driveline. | | |
