| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 3 New Guy | | New Guy Joined: Aug 2012 Posts: 3 | Hi guys I have a 58 Chevy Viking 60 I would like to replace my old 305 with a Duramax. I was wondering if anyone has put a Duramax in and what issues you ran into or any advice you have on things ill need to do the job.
1958 Chevy Viking 60.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Lots of Deisel swap advice and info over at www.4btswaps.comIf you want to go any faster You'll probably have to change the rear axle gears, you can calculate that sort of thing here. http://www.onlineconversion.com/bigger_tires.htmWith the big increase in power(and speed?) you may also need/want better brakes. A duramax swap will cost some money... Here's one of the best resources for performance Duramax stuff and I think they have stand alone computers for them. (at least from what I hear/read... no personal experence) https://www.pacificp.com/Grigg | | | | | Joined: Aug 2012 Posts: 3 New Guy | | New Guy Joined: Aug 2012 Posts: 3 | thanks for the tip. im in the process of buying a 2006 Duramax motor and trans. thanks for the links
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Curious, Why does it have a 305?
Professional Novice
