5 members (RLB, 1955 1 Series, Thomaslb, 52Carl, Hotrod Lincoln), 105 guests, and 2 robots.
Topics128,090
Posts1,056,031
Members48,433
#893413 10/30/2012 9:59 PM
I have a 1949 3600 and I am putting a 5.3 Ls fuel injection motor in it. Wanted to use a Mustang 2 front end. Has anyone done this swap and if so any pics would be great. The New Guy
There are plenty of these trucks running mustang II. You're better off to search another forum if you're looking for a specific build thread, but there are probably a couple here too.
My 46 GMC on Photobucket
Done thousands of times. Use the search feature of the site and you should find a wealth of information to help in your project. Good luck.
I see that it is done alot but no one can tell me if the IFS front end for a 1/2 ton will fit a 3/4 truck. Not sure if I should go with a universal kit or if someone could tell me the diamentions of the one listed. Just really trying to find someone that has put a IFS on a original fram (not S10). Thanks in Advance
The 3100 and 3600 frame/suspension are pretty much identical from the cab on forward. The only real difference is that the 3600 has a different axle. Any IFS kit for a 1/2 ton will work on a 3/4 ton.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
