Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (49choptop, TUTS 59, BLUEMEANIE, DES57, Peggy M, Waveski), 531 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
I have 1954 3600. I was taking the speedo apart to clean, paint and redo the numbers.After the bezel and glass came offthere were 3 fiber pieces that fell out. They are 3/4" wide and 2 3/4' to 3" long, also bent to possibly go around the speedo head. When you put them end to end they only go approx. half way around the speed head. I can't figure out where the go. They fill in a gap somewhere. Boy do I need help.
Thanks Tony
The best I remember, they go between the outer bezel and the glass, kinda inside the outer bezel. They make the glass fit tight to the inner bezel. Buy new ones. Reproductions are rubber and may be one piece, two pieces, or three pieces.
> These are from The Truck Shop. Lower left corner of page
> These are from Classic Parts
Be sure to read these two Stovebolt Tech Tips:
> Refurbishing Dash Gauge Cluster
> Speedometer rebuild for GM Art Deco Truck Lube the speedo while it is out as described in this tech tip.
> Thread on my '54 gauge and speedo reface.
- Lonnie
My '54 3104
I believe you are right, i thought they came from farther inside the unit. Many Thanks
Tony
Moderated by  ndkid275, Phak1
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.450s Queries: 14 (0.033s) Memory: 0.6016 MB (Peak: 0.6384 MB) Data Comp: Zlib Server Time: 2025-09-22 17:08:06 UTC
Valid HTML 5 and Valid CSS
