4 members (ndkid275, Hush, frogfarmer, BillCollins), 101 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
#893206 10/30/2012 11:10 AM
just had a mechanic/shop install new master cylinder and hoses on my big rig, and thought I was going to have brakes for awhile. Not true ! They lasted about 2 days (with alot of pumping) then I lost all pedal along with the brake fluid in the cylinder. I paid alot to have so little done. Anyway, he said I probably need a complete overhaul of the brakes at the hubs. Does that sound about right ? I will if it requires it but hauling this big 2 ton rig around on a wrecker is pretty expensive frown
Thanks, Troy
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
Red63 #893216 10/30/2012 11:24 AM
Crusing in the Passing Lane
If it's been sitting for a while, replace all the wheel cylinders, they are cheap, not worth fooling around w/ old ones, you can do it yourself.
EdPruss #893225 10/30/2012 11:35 AM
Thanks Ed, I will probably take your advice. Sounds like the best route to take, providing I can find the parts around here.
Troy
Troy
1963 Chevy C60
Big Red Chevy
Red63 #893229 10/30/2012 11:44 AM
Find a NAPA store- - - -they either have a lot of the old stuff in stock, or they can order it on short notice. Have you done anything about those widowmaker wheels yet? If it's got a Hydrovac brake booster, that's a possible place the fluid is going. They're bad about leaking fluid into the vacuum chamber and never showing an external leak, and rebuilding one is a real pain! Fortunately, they're not too expensive as a rebuilt exchange unit. If the wheel cylinders are leaking, there will be wet brake fluid stains on the inside of the front tires, or between the rear duals.
nothing to wheels done yet. I thought I would just use what I got..... Anyway, thanks for the advice on napa..... btw I sent you a pm.
troy
Troy
1963 Chevy C60
Big Red Chevy
Red63 #893385 10/30/2012 8:21 PM
I've been out of town all day- - - -I'll call tomorrow morning if that's convenient!
Yep !
Troy
1963 Chevy C60
Big Red Chevy
