| | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 65 | I have a 54 Chevy chassis but I think Nova rear end, E-brake pedal that will mount to the left of the clutch pedal (like newer ones). Rear cables coming from both rear shoes. What suggestions for easiest way to get this done. Thanks | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Easiest way is to use the lokar cable setup. Definitely not the cheapest though. Another route would be to use the stock cable for whatever e brake pedal you are using and mate it to the nova cables. | | | | | Joined: Jan 2011 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 65 | Thanks, I had no idea about lokar, probably will go with 2nd option. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | What is the pedal you're using out of? The Lokar setup takes a lot of the hard work out of it. | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I used the Lokar system on my 46 which has a 75 Nova rear. Piece of cake. | | | | | Joined: Jan 2011 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 65 | I don't know what the pedal is out of, like alot of parts on this rig. Slowly its all getting put together with the help of you guys. Thanks again. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Mine I just kept the S-10 pedal and mounted it to the 46 cab so I still have the whole s-10 e-brake setup, since it's on an s-10 frame. If it wasn't that easy I probably would have done Lokar. | | |
