| | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89287 11/30/2004 3:32 PM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | I'm in the final stages of restoring my 49 AD (216 engine)and need to replace the distributor. With all the bolts tight, it can be moved both up and down and side to side. The truck starts and runs fine although it does occasionaly stumble a bit under acceleration which I would think could be caused at least in part by the distributor.
Anyway, is it worth the extra expense ($250 to $300 versus $75 to $100) to go with a dual point or HEI versus a rebuilt stock distributor? The truck is basically stock. It is 12 volt, alternator, new wiring and all of the bolt on engine bits are new or rebuilt. Engine internals are untouched.. Thanks. | | |
#89288 12/01/2004 1:49 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The clamp and vacuum advance hold the distributor in place in a 216, and if they let it move too much then it should be replaced. There should be a small amount of play, the dist is supposed to float. If it wobbles around with the engine running then it has a shaft problem and needs rebuilding.
#89289 12/03/2004 3:58 AM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | ..What Josiah said ~ Big A auto parts and others sell rebuilts very affordably (under $50.00) DO NOT turn in your old dizzy untill the job is finished to your satisfaction ! .
MT sometimes has NOS ones , I lucked out and found a NOS 235 dizzy in the Delco box on E-pay for $50.00 delivered . 216 & 235 dizzy's are interchangeable per GM .
Don't pass by that old filthy greasy one on the $1.00 junk box at the swap meet either ~ often it was a takeout 35 years ago and is actually in VGC once you clean it up .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
