7 members (Jon G, Wayne67vert, KEVINSKI, 50Chevy3100, 1955 1 Series, sron48, 1 invisible), 46 guests, and 8 robots.
Topics128,012
Posts1,055,311
Members48,419
#89280 11/22/2003 12:50 AM
just bought a 37-53 carb,,I thought it was a 216,,or 235,,It won't fit on my 235 Chev engine,And i know what a 235 carb looks like,,,Anyway what's the difference between a 216,235,and 261,,I know the 261 won't fit on a 235,,Ha,Ha,,Should've looked before i leeped,,Dave frown frown frown frown frown frown
#89281 11/22/2003 4:04 AM
You got a carb for a 216 I would bet, different width of mounting bolt holes is the only difference between the two that I know of, but that is enough, as you can tell.
#89282 11/22/2003 5:21 AM
Dave,
My 261 and 235 carbs are interchangeable (at least as far as bolt-on goes - 1.5" flange). However, I understand the 261 delivers more gas than the 235 carb (different venturi throat size).
The 216 has a different bolt-on flange size. I am not sure about the pre-1954 235 carburetor bolt-on flange size.
As Brian stated, you most likely have a 216 carb (37-53) and '54 or later 235 engine. The carb and intake manifold do match (53 and earlier to 54 and later).
Tim
