1 members (Phak1), 48 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#892684 10/28/2012 12:50 PM
MFW
Offline
So, I am wanting to do a full rebuild of my GMC 228 out of my 1950. I was informed that almost all of the heads on these motors are cracked. I am in shock because I thought these were well built motors. I Want to keep this truck as stock as possible. I don't care if I can' t drive across the country at 75mph. I am aware that these trucks were built to work. I just want to restore the old girl and spend my weekends putting around and waxing her. Why are these heads so "fragile"? I guess we will see if my head is cracked before tear down. Also, anyone know of great parts resource for the 228? Thanks.
MFW
1950 GMC 100
1954 GMC 470
1954 Chevy 3100 Hydramatic
More pix on Flickr
1957 Ford 850 Tractor (video)
MFW #892775 10/28/2012 7:32 PM
I am guessing that it is a bit of an exaggeration. I wouldn't be all worried just yet.
1951 1 Ton Completed
MFW #892793 10/28/2012 8:23 PM
MFW
Offline
The truck ran well when I parked it a few years back. Smoked a bit but if I am going to restore the truck I am going through the motor and transmission. I am hoping that the head will be fine.
1950 GMC 100
1954 GMC 470
More pix on Flickr
MFW #892794 10/28/2012 8:26 PM
MFW
Offline
1950 GMC 100
1954 GMC 470
More pix on Flickr
MFW #892870 10/29/2012 6:28 AM
use it as you say and you'll have no worries. depending on how you laid it up id be concerned with the block.
MFW #892877 10/29/2012 7:30 AM
I just got done rebuilding a GMC 228 /52 and never heard of GMC heads having a problem with cracking.Go on the GMC site there is alot of info on our trucks and engines.
OldGMCtrucks.com
Pete
MFW #892978 10/29/2012 1:59 PM
A lot of heads are cracked by air pockets upon first coolant fill. A 1/8" hole drilled in the thermostat helps alleviate this problem.
MFW #893740 11/01/2012 2:08 PM
MFW
Offline
I will am keeping my fingers crossed that the head is fine. I just want the engine completely gone through before I restore the truck completely. Thanks for all the advice.
Anyone recommend a good source for GMC parts?
MFW
1950 GMC 100
1954 GMC 470
More pix on Flickr
MFW #893814 11/01/2012 7:36 PM
Patrics has all the engine parts,I just got done rebuilding a 228 and they had everything,oil pump,rings,bearings.They are very good to work with also.
Pete
