| | | Forums66 Topics128,176 Posts1,057,121 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Are the cabs the same size? Just want to know if the floorboard and toeboard from a 41-46 pickup will fit a 1940?
1940 Chevy 1/2 ton, 12 volt, 350/350th
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The cabs are exactly the same size. There are some minor differences: The firewall stamping is different, but I think the floorboards should be the same. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Bitchin Products sells a complete floor replacement for your truck for $178.00.
~Jim
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Be careful and check twice. I seem to remember Chevy advertised that the '41 cab was an inch longer. This was accomplished by moving the firewall forward. | | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Bitchin Products sells a complete floor replacement for your truck for $178.00. Do you have a link? I could not find their website. Thanks!
~Jim
| | | | | Joined: Apr 2011 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 106 | Thanks, but I don't see anything on their site for replacement steel floorboards. It looks like all they sell is sound deadening material. Am I just not looking hard enough?
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Steve: Bitchin has been around for years and easy to find on the internet. I don't know why it doesn't show up now except that it might be wholesale only. That means only retail vendors and rod shops can order the materials. This must be something new in their marketing. Try this link.
~Jim
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | They sell firewall kits, floorboards, etc. Not sure why that stuff doesn't show on that website. Might be a different site? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Sachse Rod Shop carries Bitchin stuff. sachserodshop.com Their website says: You can also call us toll free at (800) 495-3904 or (972) 495-1557 to place an order. We are open Monday-Friday 8:00-5:00 and Saturdays 9:00-1:00, central standard time.
They are local to the Dallas area but will be happy to give you information on Bitchin. Give them a call. I have found they sell a lot of products that only vendors can get and some stuff you can get direct. However their prices are the same as the vendors so whenever possible I buy from them so any problem they can handle it.They can tell you where you can find what you're looking for up in your neighborhood. Stay safe from the storm.
~Jim
| | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | Floor board for 39-40 is about an inch or so shorter then 41-46 floor board. Don't know about toe boards.
