5 members (FishinToms53, Toadwart, dt235sd, 2 invisible), 73 guests, and 1 robot.
Topics128,087
Posts1,055,999
Members48,430
#892297 10/26/2012 4:56 PM
Any thoughts on what would be an ideal donor to convert my 49 to 4WD?
It's not the weight of the load, that breaks your back. It's how you carry it.
The S10 frame swap is quite popular. Maybe a 49 body on S10 frame. I've even seen an AD truck on a Trailblazer frame. Another option is a solid front axle from a Toyota or Jeep. The rest of the drivetrain would be up to you.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
It depends what type of look you want. S10 has a narrower track width than a full size, but either would work depending on where you want your wheels to end up (width wise) and how you want the truck to look.
My 46 GMC on Photobucket
49oldandslow #892677 10/28/2012 12:13 PM
I've got access to a Jeep Wrangler, any ideas on what problems I'll have? Ever heard of anyone doing this before?
49oldandslow #892922 10/29/2012 10:58 AM
What year of Wrangler? The first thing is that if your 49 is a short box, you need a wheelbase somewhere around 115-117 inches, and only the 2007+ 4-door wrangler has a long enough wheelbase. If yours is a shorter wheelbase, this can only be fixed be lengthening the frame, and that is MAJOR fab work. I have no idea if the width of the wrangler frame or track width would work either.
Is '49 an AD truck, or earlier? If it's AD some of those Napco conversion kits might fit. If it's 3/4 ton or 1 ton; I'm not sure about half tons.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
Ed, I'm a bit foggy as to when NAPCO started adding the 4wd to the 3/4 ton and up trucks? Wasn't Colman in the biz too? Talk about rare though.
I don't know what year it was, but an AD Napco kit ought to fit any AD truck of the right weight catagory. I just love the look of the Napco equipped AD trucks. You're right though, they are definitely less common.
I haven't read about Coleman doing Chevy trucks that late. I wish I knew more about the early companies like them.
Ed Miller
Falls City, OR
