10 members (Bill Hanlon, pdlightning, 1955 1 Series, dt235sd, mo2cyl, FAST55, Steelonsteel, MikeE, sron48, klhansen),
75
Mod | | | Forums66 Topics128,050 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | I got the front grill assembly buttoned up plus the light buckets and radiator, moved the engine forward 4.5" which improved things all around will post pictures also watch out for the caged leaper, I thought it was a nice touch. | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | I have the fuel injectors back from cleaning and testing fitted onto the fuel rail new seals and hoses, air intakes cleaned up and modified, air induction system blocked off, exhaust manifolds sprayed with high temp paint welded a 2.5in flex pipe to the down pipes, new oxegen sensors, now ready for a set of side pipes will post some pictures later and update my album | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Nice work, will you be out in it this year? | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Hi Stu,
I should have the engine running this summer, the cab needs a lot of work plus I need a bed and so many other bits and pieces so no I will not be out in it this year
cheers Paul | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I will not be out in it this year
cheers Paul Paul,that just sounds so painfully familiar! Joking apart, keep up the good work,if you approach the bodywork with the same professionalism as you have done with the running gear,it'll be a fantastic truck. It'll be done when it's done.......  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | the build looks great. looking at the pictures I am impressed. However are those just cracks in the primer for the outer rear hubs, or do your castings have stress cracks?
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Hey Scott,
They were cracked I had them ground and welded XJS is a heavy car and on bad roads its a common problem in the States.
John I did not buy a welder just to make the garage look good its time to pay me back and boy do I have a lot of work for it but it keeps me out of the pub ;-) | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | I bought another donor car $500 1987 XJ-S V12 Coupe the guy drove it to my house seems a shame to break it but needs must, has new alternator, steering rack, steering pump,poly bushings, brake pads,tires on lattace sport wheels all in the last 12 months to good to pass up
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That's a deal and you can probably sell off parts you don't need if you want and get your $500 back.
Drew
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Distributor rebuilt and fitted, new plugs and wires, new mallory coil, rebuilt ign amp, throttle tower in new TPS ready for rewire. Started work on the cab a lot of stress fractures to be repaired and a lot welding to be done check pics on flickr | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Paul,I see one of your pics was titled "Just before it fell off the lift."  I hope you're OK and there wasn't too much carnage to the truck either?
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Yeh it was like in slow motion its kinda firwall heavy and the tie back let me down, I was stood at the side and could do nothing it dented the front fire wall so it was an easy fix. Trying to find some info on converting from the opening front wind screen to a fixed sealed type do you know anyone that has done that? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Trying to find some info on converting from the opening front wind screen to a fixed sealed type do you know anyone that has done that? Funny Paul,it's usually guys wanting to go the other way,to get the opening windscreen to work! I'm not familiar with the windscreen aperature 'anatomy' but I'm pretty sure you could bond a screen in. I'm a glass guy to trade and would relish the challenge,only problem is the travelling time would be hideous (and expensive)! I know a few guys in the HAMB in Va,i'll put the word out and see what I can find out. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | The PO must have got a plasma cutter for Christmas he cut everything out including the hinges for the wind screen all the supports and bracing for the cab and doors so a lot more work than anticipated I will check out the glass shop cheers John
thanks Paul | | | | | Joined: Dec 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 66 | Just looked at your pix. Very straight rear of cab and fire wall. Entire cab looks realy sraight. My cab rear took me a month to straighten. Great project. Al | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Just added few more pics engine is dressed need to start wiring | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Knowing you fabbed and modified the front end and relocated some, it's still surprising to me to see how well and low the V12 fits the chassis. I think your "day job" experience puts you ahead of any of us to try to do that mod. Really hope to see the completed rod some day, somewhere.
Drew
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Hey Drew,
The V12 is at 60 degrees which makes it narrow but long its taken a lot of planning to get this far, when I see front ends priced at $3000 and back ends at $5000 people shy away from the Jaguars but at $500 for a used XJS its a steal, a lot of engineering for little money. I am sure there will be a few more changes along the way but its been fun so far, the day job sure does help but my training and previous experience is the key.
cheers Paul | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Had a major mock up yesterday set the cab position need to add a six inch wide strip to the cab or hood I want to vent this piece to help the air flow, got some good ideas on where I want things, thought about a really cool cold air intakes positioned just under the head light brackets. Added some pics to the album
cheers Paul | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Fitted the Jaguar brake master cylinder and booster last weekend using a custom frame mount, this made more sense than using a different assembly as the XJS has excellent stopping power with discs all around. Will need to modify the pedal location and make a coupling but both are an easy fix, couple of new pics in the album
cheers Paul | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I had seen the pics earlier Paul,nice job as usual. Like I commented in Flickr it makes sense to use 'matched' components,at least you know they were designed to work together.
BTW.Were Jaguar not the first manufacturer to install disc brakes on a mass produced car? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | They were indeed John, they introduced discs (rotors for the US)in there racing cars and wiped the floor with everybody, the other teams complained they were cheating the judges then discovered all the Jags had disc brakes and thats why they out performed the other cars. it was not long after that they apperaed in production cars late 50's early 60's | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Paul,thanks for the clarification,it's just I remember seeing an old MK2 Jag a while back with an enamel badge on the rear bumper proudly proclaiming the fact.
If memory serves they were developed on the D type Le Mans cars. Now there's a Jag I wouldn't mind owning!
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Thats right John Le Mans winning D Type's I like the C Type better but the ultimate is the XJ13 "Now there's a Jag" | | | | | Joined: Dec 2010 Posts: 25 New Guy | | New Guy Joined: Dec 2010 Posts: 25 | Any updates? I'm dying to seen more pictures! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Me too, seems like I have been following this project forever.Going to be worth the wait. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Don't the English refer to the windshield as a windscreen?
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | sorry guys I have been busy with the truck I will post more pics on flickr, BTW windscreen is correct term British people use
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Not much to take pictures of, I have been making up my wiring harness and connecting lights and other things | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | I made the last of the wiring harness's today and thats installed all I need to do now is connect everything then the fun will start see what fuses blow first | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | first to blow electric cooling fan fuse 15amp not big enough 30amp installed works great,horn and lights work,engine cranks over thanks to a gear reduction starter and I have a big fat spark at the plugs, need to add fuel and coolent and maybe we will have a running engine, posted a few more pics | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | What electric fan are you running? I have a 2500 CFM flex-a-lite that calls for a 40 Amp relay. Just for a reference. | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Not sure what it is had it for a few years lost the box and instructions I will put my current clamp on the feed wire and see what it draws, it seems happy at 30 amps | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Have been wiring the lights and other circuits this week, wired my Oxygen sensors today I think thats all the major wiring completed and working, posted a few pics of the dash board well pleased with the way it turned out | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Very clean look while using very modern gauges. A really nice approach. That is also an outstandingly finished steering wheel. It's yacht quality.
Drew
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Thanks, I got the look I wanted, steering wheel came on an XKE I restored had to buy the boss for the XJS steering column, I agree it has a great finish and goes well with the polished aluminum | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Just scrolling thru your photo album. What a great project ! You obviously have the skills to take on a hybrid like this. Looking forward to seeing the completed. Great job !!! | | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Thanks to everyone who is following my project and for the positive comments, I have picked up some negative flak for other so called Hotrod sites for being "none traditional" I see it as I saved a Chevy from the crusher also a Jaguar drive train and I fueled my ambition to build a custom pickup truck. I need to get my bottom hose sorted out so I can run the engine, maybe I will have a go at posting a video of the startup.
Thanks for taking an interest it inspires me to push on. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Have to laugh at that comment from other sites. Since when does "Hot Rod" mean cookie cutter cars.  Years ago I saw a '32 Ford/XK120 engine project. JUST KEEP TRUCKIN'!
Drew
| | | | | Joined: Jul 2011 Posts: 176 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 176 | Its become a "Cottage industry" you have to have, small block chevy,350 trans,mustang II front end,9 bolt rear end that is "Traditional" or so they say. If you have this set up and it works for you then god bless you but dont critisize me for being different.
This was my reply to the other websites
