7 members (mo2cyl, 1955 1 Series, FAST55, Steelonsteel, MikeE, sron48, klhansen),
91
Mod | | | Forums66 Topics128,050 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89252 05/22/2002 6:26 PM | Joined: Dec 2001 Posts: 21 Member | | Member Joined: Dec 2001 Posts: 21 | ok, if the answer to this one is really obvious, please be kind!!!
have been rehooking up wiring, got battery in, lights work, engine turns over (doesn't start yet, but that's another story), and things look fine EXCEPT ... :confused: the votage guage goes to the postive side (_/_) when you apply load (ie. crank the engine) instead of going to the negative side (_\_) :confused: . Checked wiring (to best of my limited ability) and looks ok.
any ideas?
64swb
#89253 05/23/2002 2:42 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | One of two things, did you change the wires on the back of the amp meter, or stick the battery in backwards? | | |
#89254 05/23/2002 3:28 PM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | REMEMBER ALOT OF TRUCKS WERE POSITIVE GROUND UNTIL 55. TO CHANGE YOU NEED A NEG. GROUND REGULATOR. SOUNDS LIKE THE BATTERY IS IN BACKWARDS.  | | |
#89255 05/23/2002 6:24 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year?
GMC or Chevy?
6v or 12v? | | |
#89256 05/24/2002 4:44 AM | Joined: Dec 2001 Posts: 21 Member | | Member Joined: Dec 2001 Posts: 21 | :confused: knew it would probably be something simple....i just didn't have enough stuff hooked up. got the headlights in today and sure enough...turning them on shows a discharge on gauge. battery is definetly in right, negative ground etc. fuel gauge and wipers work. still shows a charge when cranking engine and I would have thought draw would show discharge at that point?? ps. its a 64 v8 with the 3 wire alternator and separate volt regulator. thanks for responses.
64swb
