0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#8922 03/19/2003 6:04 PM
on my '31, i think i would like to retain the 6-lug bolt pattern so i can keep my tall & skinny tires. at the same time, i would like to install a drop axle for a little 'altitude adjustment'. while purchasing said axle, i am given the option of using 42-48 f**d or 49-54 chev spindles. is there any 6-lug drum brake that will adapt itself easily to either of these spindles? would i be better off using 49-54 spindles with the original drum brakes and buying new 16" rims?
thx
ed
#8923 03/19/2003 8:09 PM
The easiest would be to take your original axle to a shop that does such a thing and have it bent to any desired drop. Properly done it is as good as the original piece and everything still fits.
There is a shop here that does it.
54 3100 with 235
62 flatbed dump C60 with 261
#8924 03/19/2003 11:46 PM
i've definitely considered that option tony, but i would also like to upgrade to hydraulic brakes while doing the axle swap. also, i called around a little bit, and it seems that it would be cheaper to buy a dropped axle. thanks for the input.
ed
#8925 03/20/2003 12:53 AM
If you want to keep the six lug wheels try using 51-up truck drums and brakes,they are six lugs and have the modern style shoes. From what I have heard the 49-54 five lug drums and brakes fit the 1/2 ton trucks so trucks should work on the 49-54 car spindles
#8926 03/20/2003 11:20 PM
If you go the dropped axle route and get the 49-54 spindles get the drums and brakes with it. I will trade you 51-up truck six lug drums and brakes for the car parts,I was going to keep my 37 six lugs but have deceided to change to five lugs
#8927 03/21/2003 5:52 AM
jeff,
tex smith's 'how to build chevy hot rods' has a write-up on swapping the 49-54 car brakes to truck spindles. i'm looking over the article, and i'm not so sure that the swap would work in reverse. tell me this: does the stock pickup setup use a spacer between the spindle mounts and the backing plate? if you'd like to look over the article, i can photocopy it and fax it to you.
ed
#8928 03/21/2003 9:12 AM
Yes it does use a spacer
#8929 03/21/2003 8:35 PM
so then i do believe that the truck brakes would swap over to the car spindles.
#8930 03/24/2003 5:00 AM
Spend some money and get the six-lug disc brake set-up by some of rod brake places advertising in magazines!
Only thing diff that I know of on 54 spindles compared to earlier is the bottom two holes are bigger where backplate bolts on and steering arm. I had a 49 that they reccommended using 54 up, I just drilled out the holes. Looked like plenty of metal in them yet to me!
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
