6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#892411 10/27/2012 7:18 AM
I have a 3 speed manual transmission out of a 1950 chevy that needs work and suspect worn gears. Will the gears from a 1955 chevy be compatable in order to be used for replacements?
DJRoy #892472 10/27/2012 11:48 AM
You can use the side cover and possibly the clutch gear but I beleive the remainder of the internal parts are different.
Fred
DJRoy #892474 10/27/2012 12:10 PM
There were 2 models in '55.
like cletis said, there are early and late types in truck transmissions in 55. Most but not all of the parts in a Chev 3 speed interchange from 1940 to 1954 and 55 1st truck. The cluster gear interchanges with much later transmissions.
My Blog
