| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | I have a 3 speed manual transmission out of a 1950 chevy that needs work and suspect worn gears. Will the gears from a 1955 chevy be compatable in order to be used for replacements? | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You can use the side cover and possibly the clutch gear but I beleive the remainder of the internal parts are different. Fred
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There were 2 models in '55. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | like cletis said, there are early and late types in truck transmissions in 55. Most but not all of the parts in a Chev 3 speed interchange from 1940 to 1954 and 55 1st truck. The cluster gear interchanges with much later transmissions.
See the USA in your vintage Chevrolet! My Blog | | |
