| | | Forums66 Topics128,106 Posts1,056,211 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | has anybody have suggestions as to how to best remove interior paint one layer at a time? I have parts of my interior that were painted and I would like to attempt to remove only the resprayed layer leaving as much of the original paint intact. It is estimated that the respray was done in the 60's.
Any suggestions?
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | My experience is that most strippers only remove one layer at a time. I would use a water base stripper and a scotchbrite pad. Lay a uniform layer of stripper down with a brush and wait a few minutes then scrub it with the scotchbrite pad and warm soapy water. Do small areas at a time, no more than two square feet.
When you are finished I would lightly go over everything with rubbing compound to make the newly exposed finish look uniform.
Well, that's what I would do.
Joe
1955 First Series 3100
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | nothing underneath a stripped section would be worth saving after using chem strip and a sand blaster set down about 35psi and a trickle might get you there, but I'd rather try doing surgery than take a layer off and NOT take the good stuff along the way. Making a repaint the inevitable solution it seems to me
