7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy), 67 guests, and 3 robots.
Topics128,130
Posts1,056,713
Members48,454
#892236 10/26/2012 10:46 AM
I am sure this topic has been here before but i wasn't. Can you turn the old steel drums from '36 1 1/2 ton? I am sure everybody that has one knows what happens to them when braking for so many years,they have that "lip" on them. What can be done if anything? Thank you again, Dan
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
3B Offline
Hy baldbenny, yes those drums can be turned, it seems to me we wrapped a large rubber band around them to prevent the ringing noise and probably to help stop chattering. Now we have nice carbide tool bit so we probably get a nicer cut. You can't take out as much per pass as you can with the iron drums, and definately use the slowest feed on the machine, hope that helps.
Thank you 3B! I just didn't know if people cut them or ground them, Thanks again, Dan
