| | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | does anyone know of a vender that makes patch panels for rear fenders? thank you . i only seam to find front fender patches. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | most vendors have a patch for the area that attaches to the running board - like here, and here - if you need other areas it'll be a DIY job Bill | | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | thanks red 58 i didn't see your response i was working and then there was that kick [censored] storm. ( i lost power for 5 days but all is well, we are blessed. many in n.y.c and areas around could use a prayer) | | |
