1 members (JW51),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Just a small detail...looking for originality here!
Was a stencil originally used to paint the lettering/numbers on the valve covers of our Stovebolt engines? If so, were they sprayed or hand-lettered?
Thanks for any insight on the topic.
LUKE | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Luke - Here are some old posts that pondered the subject ... > Old post #1> Old post #2FYI - I had a vinyl sign shop cut the ThriftMaster235 decal for my '54. Looks better than any mylar decal that most suppliers sell.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | I think Denny Graham made some stencils - check out his pics. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | LUKE,
Are you referring o the lettering/numbers on the upper side of the valve cover (tht Zlonnies covers) or are you referring to the lettering/script on the top of high pressure 235/261 engines' valve covers?
| | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | Thanks for the sharing the info. It was interesting reading. Denny Graham's work thoroughly covers the questions I have. I sure would like to easily be able to do the same thing that Denny showed all of us. The repo. decal/sticker is just a bit cheesy if you ask me!
As always, this is such an awesome forum to learn about the trucks we all love. Thank you to everyone for sharing.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Can someone please post a link to Denny's graphic as described above. I tried to find it but, cannot seem to locate it. Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Just shot Denny a PM. ...I have a friend who owes me some cnc work. Might see if he can cut me an aluminum stencil that I can loan out to other bolters for a deposit. The repo. decal/sticker is just a bit cheesy if you ask me! AGREED!! I purchased a decal but wasn't satisfied with the look so I was thinking about making a stensil too. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I was gonna paint my ThriftMaster 235 logo with a vinyl stencil. I had a vinyl sign maker cut a couple of stencils. They looked good so I attached one to the flat side of a gallon can of paint thinner to test the process.
The vinyl stencil layed down smoothly. It sealed the edges of the open areas so that no paint weeped underneath. I had trouble finding the proper mixture of paint to thinner to spray with my air brush, but that was my problem, not the fault of the stencil. A rattle can of Rustoleum yellow would have probably worked better.
However, a problem arose when I tried to remove the vinyl stencil. It stuck to the steel can too well. It left a ghost on the paint can that I had attached it to. The sign maker said that he did not have any vinyl material that was less sticky or that was meant to be easily removed.
Rather than experiment more, try to buff out the ghost, or find a chemical method that wouldn't damage the newly painted logo, I elected to have the sign maker cut a yellow vinyl logo that I could apply directly to my valve cover. I'm happy with the results.
>> LUKE: Look for a new PM from me regarding the stencil.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2009 Posts: 791 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 791 | I tried using the "mask" method and was not completely satisified. With my "no quit" attitude now in high gear, I turned to my friendly craftsman at local sign shop. The lettering was done via an "ink transfer" similar to the process used to apply the old water slide decals that I remember as a kid building models. There is no clear backer used. The lettering was set with a high heat engine enamel clear coat. Please click on the two links below to see pictures of the final products: http://s160.photobucket.com/albums/...ky/?action=view¤t=DSCI0755.jpghttp://s160.photobucket.com/albums/...ky/?action=view¤t=DSCI0749.jpgThis took a little time, effort, and $$$, but I sure do like the end result better than the cheesy decal/sticker available from the vendors! I have a couple of sets left over that I will advertise in the "Parts Wanted" forum. | | | | | Joined: Jan 2009 Posts: 17 New Guy | | New Guy Joined: Jan 2009 Posts: 17 | What lettering are you referring to? I have a 50 valve cover that has GMC stamped into the top. Never seen this before. 1953 GMC 9300In the Stovebolt Gallery[url=http://s871.photobucket.com/albums/ab277/silver90_photos/1953%20GMC%209300%20Five%20Window/More pix on Photobucket[/url]
| | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | I have a 1956 235 ci engine and it is a Load master engine also but not sure if any thing was writen on the valve covers or what that font is or what, how it says it or any thing. Help | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If a decal or painted lettering was used on the 6-cylinder valve over in 1956, it is probably shown in the Factory Assembly Manual. Maybe someone with a 55-59 FAM will comment? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 56 would have been a decal, not painted .... unfortunately the 55-9 assembly manual doesn't show any decal on the 235, likely because the same views are used for all the different models - the only original I've seen was the 'New Thriftmaster', which decal is well reproduced
Bill | | |
