Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Otto Skorzeny, Hotrod Lincoln, Bill Marlow, baldeagle, 1 invisible), 61 guests, and 4 robots.
Topics128,006
Posts1,055,268
Members48,418
#89170 02/06/2004 3:49 AM
My headlights are getting almost nonexsistent and the blinkers wont work unless i gun the engine.The belt is tight.If i remove a battery cable the engine stays running.Its winter so keepin mind if the truck is running the heater is on high.Is this a generator or a regulator problem?This is on my 6-volt 51.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#89171 02/06/2004 4:13 AM
could be reg - if it isn't part fried, it is possible to adjust it to increase gen output so charges at idle w/ some draw [careful - not too much], but you may also need brushes in the gen, or the batt could have a weak cell - get a load test done on batt and check brushes/ gen output first
#89172 02/06/2004 8:34 PM
Would just changing brushes cause a generator to need to be re-polorized?
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#89173 02/06/2004 11:35 PM
I've changed brushes a few times and don't remember ever polarizing - course, that don't mean the next failure wasn't my fault! grin
were yours ground down pretty short? did the armature look real dirty and scored? don't think ya need polarizing if the generator never stopped gennin, or if ya didn't replace the regulator
#89174 02/07/2004 1:55 AM
The original 51 generators brushes were worn way down so i replaced them,put it back in and it didnt work any more.I removed it and put in a salvage one. If memory serves me corectly i also droped it.I will pull the one in the truck tomorow and see if i can figure it out.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#89175 02/07/2004 2:12 AM
Slow . . Rider,
I learn't that any time you disconnect the generator or battery (or the voltage regulator) you should polarize the system. When in doubt, jumper the Batt terminal to the Gen terminals on the voltage regulator - a spark will fly.
Of course, the good old boys that taught me are backed up by every shop manual that I've seen.
This might not be the answer to the problem you describe, but it will keep your generator from getting mixed up thinking it is sometimes a generator (when the engine is runnig) and sometimes it should try to spin as a motor (when the engine is not running).
Yes, I know there can be a residual polarization for a certain period of time, but why take a chance?
Curmudgeon
Let's play together nicely.
#89176 02/07/2004 4:17 AM
Wich isthe hot wire,F or A? Im going to try and reinstall and polorize the original and dont want to hook it up backwards.The brushes on this one were very short.It was the first time ive replaced them but im prety sure there in corectly.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#89177 02/07/2004 4:59 AM
F and A go to F[ield] and A[rmature] on the regulator - seems to me that F is the heavy gauge wire so that'd be the hot one - good to have a ground wire from gen case to reg mount screw too
#89178 02/07/2004 7:31 PM
Ok guys,i now have blinkers,high beams and heater all at an idle.I belive though that i have the the field and armeture wires flip floped.Can anyone verify that the F field wire is the heavy guage wire and the A armeture wire is the thin guage?
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#89179 02/07/2004 8:40 PM
Slow..Rider,
Double checked in the book, Fat wire is the armature and thin wire is the field.
You can verify that the generator is operating correctly on the bench by motoring it. I used my battery charger with an ammeter in it to test the last one I did.
Jumper the field terminal to the generator frame. Hook the negative battery charger lead to the generator frame. Touch the positive charger lead to the Armature terminal on the generator and it should run as a motor drawing from 4 - 6 amps for a 6 volt generator.
Make sure you've got hold of the generator before you hit it with the positive lead. It jumps pretty good when you hit it with the juice.
This also polarizes the generator in the correct direction.
To polarize on the truck, momentarily connect the BAT terminal on the regulator to the ARM terminal.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#89180 02/08/2004 3:54 AM
Thanks for all your help guys,i can now drive safely in the dark again.Amp guage isnt working but i can live with that till spring. smile
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
