1 members (Rusty Heaps), 114 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#890970 10/21/2012 10:11 AM
I have a 1954 chevy 3600 that i would like to swap a Dana 60 rear out of a 1971 c20 3/4ton into.
Been having trouble finding axle width measurements etc and wont be by my truck to take measurements for another couple weeks.
Curious if this is a feasible option.
1954 3600
[/url] www.tors54.tumblr.com
Chooglin #890982 10/21/2012 10:45 AM
Try searching www.chevytrucks.org That site has charts with dimensions on various rear end swaps for AD trucks.
Drew
Chooglin #890986 10/21/2012 11:02 AM
Chooglin #890987 10/21/2012 11:26 AM
Chooglin Go to this link http://www.pirate4x4.com look in Brand Specific Tech. Under Chevy----- Got an axle question? Check here first! There is a bunch-O-reading on axles.
T-RUCK #890995 10/21/2012 12:32 PM
Great!
Thanks for the quick replies guys. Ill start lookin through those articles and see what i can find.
Chooglin
1954 3600
Chooglin #891225 10/22/2012 9:58 AM
I put the same unit into a 59 Suburban, and had a lot of tire-clearance problems with the rear wheel openings. The axle was about 2" wider at the wheel attachment flanges than the original rear axle. If you're running a flatbed instead of a stepside bed, the width difference might not be apparent, but I believe the early 50's track width was somewhat narrower than the 55-59 models.
Chooglin #891601 10/23/2012 11:23 PM
Your stock axle is going to be about 62.5" WMS-WMS(Wheel Mounting Surface). I don't know much about the Dana swap, though. I'm going to try to steer you into the 14-bolt full float direction. Most of your dually equipped GM trucks from 73 on up have 63" WMS. I purchased one that was actually 62.75". You'll have to cut and relocate your spring perches and shock brackets if you go this route though. If you can't find a dually axle you can alway use an axle from a single wheel truck and use your Eaton hubs. The Eaton hubs will give around a 65" WMS. You'll have to get creative with your brakes though. Fortunately GM has probably a dozen different options for the 14 bolt.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Chooglin #891604 10/23/2012 11:36 PM
Getting one from a van is another option. Vans seem to run a bit narrower that trucks, I do know that one from a mid '80s Dodge van will fit without clearance problems. I do not recall the exact dimensions, as we did the swap almost 20 years ago, but we did run the truck with the stock 17" splits and 7.00-17 tires, then later with 8.00-16s with no rubbing. The truck in question was a '49 3800.
Bill Burmeister
