| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | We're planning on rewiring the tail lights on our 49 Chevy 3600 this weekend.
-What gauge wiring should we use for 6 volts?
-Is there a website I can geek out on that carries wiring and connectors for old trucks?
-Long shot here; do folks have pictures of wiring they've done so we can get some ideas on how to run it, connect it, clip it, loom it.. etc? This site has been instrumental in helping us get the truck running.
THANK YOU! J&K
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy JungleJames, the factory gauge for the tail/stop wiring under the truck is 18ga., up to that point it was 16 Ga. hope that helps. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | 18 ga will work fine for tail lights it can handle 7-10 amps no problem. I always go larger 16ga. Make sure you have a good ground. I ran a separate ground. Not stock but can keep you from having issues over time. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | This wiring diagram for a 1950 truck shows the gauge for each wire. http://chevy.oldcarmanualproject.com/electrical/wiring/pdf/50truck.pdf- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Indeed it does. It shows 16 ga. for the tail/stop lamp. 18 sounds a bit light to me for a 6v system but I'm certainly no expert.
