0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | Does the bed come apart in sections? It looks like the front part of the bed, both side panels, the parts that hold the tail lights, and both fender wells come apart, but I don't know if it is welded in spots or if it is all just bolted together. Please let me know. I am going to try and buy a assembly book here in the next couple of weeks. | | | | | Joined: Dec 2009 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 52 | I asked the same question a couple of weeks ago. Here was the response:
There are two stich-welds on each end of the rear main cross sill...one on the top of the sill and one on the front face. With a cutting wheel in a die-grinder, they can be scored and the bed sides can be removed from the rear main cross sill.
There are also four shoulder bolts on each end of the rear main cross sill, securing it to the bed sides.
| | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | Thanks for the advice...I have just the tool for that...angle grinder with cutting wheel. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Boomer,
call MAR-K they have a booklet for $5.00 that will help you put her back together (reverse it)
jake | | | | | Joined: Sep 2012 Posts: 19 New Guy | | New Guy Joined: Sep 2012 Posts: 19 | Not sure if you are talking fleetside or stepside. Just disassembled the stepside bed and everything is bolted. | | | | | Joined: Mar 2011 Posts: 27 New Guy | | New Guy Joined: Mar 2011 Posts: 27 | Thanks guys. I have been gone a while. The good thing about Mar-K is they are right up the road from where I live. I am going to get that booklet and I will more than likely be using them for all of my longbed fleetside needs. Thanks again. | | | | | Joined: May 2010 Posts: 32 New Guy | | New Guy Joined: May 2010 Posts: 32 | does any body had pic of the weld spot on a 1965 c10 fleetside | | |
