1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#891493 10/23/2012 2:38 PM
hey,
i have a 59 stepside with a munice 318 i believe, it has a column shifter, i have to play around with it to find the correct gears and i cant seem to find the first gear at all, not sure if its the shifter or the trans?
jesus209 #891558 10/23/2012 8:24 PM
Probably the shifter. Check to see all the shift rod connections are tight. It may need new bushings. Also check to see that the neutral position goes from the first-reverse plane to the 2nd-3rd plane and back without having to be jiggled. This can be adjusted out.
