| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89154 05/26/2004 4:35 PM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | I have recently aquired a 1949 3100 with what I believe to be a 1954 235 engine in it. The block is marked casting 3835911 by the fuel pump with F54Z stamped next to the distributor, and the head is casting 3835913.
I am ready to spin the engine after an unknown time of it sitting unused. The engine spins by hand with the plugs out, and all the valves move when I turn it by hand.
It looks like it was converted to 12 volts at some point. Generator is marked 12V and there is an ignition ballast resistor?? mounted on the firewall (a white rectangular ceramic looking thing with a wire screwed to each end). There is no battery right now.
What size battery should I buy?
Can I just use jumper cables from my daily driver 1988 K1500 to see if it will spin before I buy a new battery? How can I know for sure if its negative ground?
Thanks!!! | | |
#89155 05/28/2004 6:03 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I would go ahead and jump it. It's going to be a neg. ground. Chevy came with neg. ground, GMC with positive. There is no reason why anyone would want to switch to a positive grd. Also, if the gen. says 12V and it has a resistor then its a 12 volt system. Now, having said this, you don't know if the person who had it wired did it correctly. So, you still could have some problems, but getting the juice to it is your next step and see what goes from there. | | |
#89156 05/28/2004 2:26 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Make sure your medical insurance is current and stand back when you hit the switch, just kiddin  :p
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#89157 05/31/2004 1:55 AM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | Hope I'm not too late to weigh in. I agree with all thats been said but wanted to add that my 54 was converted by one owner to 12 volt. He sold it to someone else who began converting it back. He then had to sell it and guess what I got - a mess. BE SURE TO GO OVER EVERYTHING FROM POINTS AND CONDENSER TO VOLTAGE REGULATOR, STARTER - YOU NAME IT, before you try and jump it. You might just save a few dollars by replacing/rebuilding something instead of frying it.
Good luck!!
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
