9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman),
93
Mod | | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | whats the trick on removing the drive shaft ,, i see there is 2 bolts that hold carrier bearing ??? and it slides out front or back ??
thanks
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Remove the ubolts holding the driveshaft to the rearend so you can pull the rear shaft out. Then you can unbolt the carrier bearing. Remove the 4 nuts from the front shaft at the trans. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i did that and tried to slide it out the rear and it wont even the front , do i need to remove the center carrier before i try to slide it out ??
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Take the rear shaft out first, It may be a little stuck and need some persuading but it should slide off the splines behind the carrier bearing. If I remember correctly the carrier bearing stayed on the front shaft when I took mine out. You cannot get the front shaft out unless you completely unbolt the carrier bearing. It comes out with the front shaft. You may also have to persuade it to break loose from the trans. Darren | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | right now i have the motor and tranny out ,, i tried to slide it out the rear and saw a round bearing like thing but it wont come out that way like its hitting on ( the center support ) now that i know this mm it wont slide out the front either so i am thinking i need to loosen the 2 bolts and that will let the center bearing housing move with it ??? it will move a great deal front and back , i say its hitting on center suport
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | mine might have come apart? Cause when i slide to one end ther is something like a bearing that spends, so it might come apart, unless it is supost to?
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | I really dont see the holder, all i see is the center bearing when i slide it to one end, i can spin the bearing then, , i say its come out of the holder,, i will take the bolts out this evening and see, thask for helping me, ill get back with you and let you know
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | just thinking should i use a sealed universal joint for the middle because you cant get to it to grease can you ??
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | | | |
