8 members (HandyAndy, 52Carl, 55shaker, Cosmo, RoadsScholar, Jay R, Ponchogl, 1 invisible),
76
0
Mod | | | Forums66 Topics128,049 Posts1,055,629 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 23 New Guy | | New Guy Joined: Oct 2012 Posts: 23 | hey, i have a 59 stepside with a munice 318 i believe, it has a column shifter, i have to play around with it to find the correct gears and i cant seem to find the first gear at all, not sure if its the shifter or the trans? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Probably the shifter. Check to see all the shift rod connections are tight. It may need new bushings. Also check to see that the neutral position goes from the first-reverse plane to the 2nd-3rd plane and back without having to be jiggled. This can be adjusted out. | | |
