Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Cletus1950, TUTS 59, Wayne67vert, SmalltownTRKGuy, Otto Skorzeny, UnclePaddy), 146 guests, and 3 robots.
Topics128,281
Posts1,058,462
Members48,490
#891383 10/22/2012 10:28 PM
Y
Y Offline
Hello all,
I recently purchased a 1951 GMC 350 2 ton and the piston connecting rod broke. I also suspect a small crack in the engine block. I am looking at rebuilding replacing and possibly even swapping for a newer engine. Does anyone have specs or ideas for a new engine for this truck.
If you would like to keep your truck a 6 cylinder, there are many available that are direct bolt in replacements for your engine. I assume your motor is a 228 6 cylinder. There is a flat pad on the engine where the distributor goes into the block. There should be a motor serial number stamped on the pad. The first 3 numbers of the motor serial number are the engine displacement. There also might be an issue with 6 volts vs 12 volts.
If your truck has the GMC 6 you could use any 1939-1953 228, 1939-1956 248, 1941-1959 270, or 1951-1959 302. 1954 and later engines might pose some problems due to a different front motor mount setup. Additionally some gmc motors have 4 lug flywheels while others have 6 lug flywheels. The flywheels from bigger trucks are different than the flywheels from the 1/2 ton through 1 ton trucks.
Y
Y Offline
Thanks for the info. The truck has a 248 in it. I am looking around now for a replacement. I will probably go bigger if presented with a choice. Have a nice day.
-Yori
yori....check the adds at OLD GMC Trucks and Inliners.org.
I see Jimmys for sale in there quite often.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Y
Y Offline
Thank you very much. I'll check it out.
