4 members (55shaker, rfs56trk, Otto Skorzeny, FAST55), 171 guests, and 3 robots.
Topics128,078
Posts1,056,051
Members48,433
#891320 10/22/2012 5:53 PM
The fitting on my Carter YF 2101S autochoke has broken off. Does anyone have any ideas how to fix this. Would JB Weld be sufficient to put a new fitting on there? Here's a pic of how it looks.
Broken fitting
Broken fitting
no pic
Let's try again
Broken Fitting
Carburetion specialist
The easiest way of which I am aware that works would be to make a new "repair" fitting out of a piece of hex brass.
Internally thread the remains of the projection on the airhorn.
Make the repair fitting with male threads to fit the female threads you made in the airhorn, and "burr" the male thread slightly. Thread the other end of the repair fitting with the proper thread for the cap on the heat tube. Leave enough of the "hex" to hold with a thin wrench.
Now screw the repair fitting into the airhorn. The "burr" will cause the thread in the fitting to "seize" in the airhorn and stay in place.
As an insurance that it stays in place, hold the fitting with a thin wrench when installing/removing the heat tube.
Jon.
The Carburetor Shop
I hadn't thought about putting internal threads on there. I'll have to look into that.
Finally got around to fixing this. I hope.
First a little better picture of what I was working with.
Broken threads
Now for the fix. I started with one of these
Edelmann Part # 744460
Thats a 1/8 NPT to 1/4 hose fitting. This is what I did to it to make it fit.
Modified fitting
Drill press and a file will remove material. Not the best way to do it but it's what I have access to at the moment.
Here's how it fits
Fitting in carb
To hold it in place first I used some High Strength Sleeve Retainer Napa # 765-1149 that I had left over. After it dried it held the fitting in place. To make sure I don't have a vacuum leak I used some JB Weld. Here's the finished results.
Final Pic
