| | | Forums66 Topics128,272 Posts1,058,316 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Hi All, Well, 10 years after having to part with my 46chev and 54 gmc3/4, a 1953 3100 deluxe cab followed me home. It was an offer I couldn't refuse. Just when I thought I was out, they pulls me back in. This thing of ours. What sold me was the cab and doors condition. Somebody brought this one back from the southwest, then left it out in the yard in VA for a year or so. Surface rust, but so far, I have only found two < 1/2" holes in the floor kick area. Otherwise very solid, with original 216, 4 speed. All original clutch head screws and hubcaps in place. A 1/2 " layer of "that stuff" covers all the engine and trans - you all know that mix of oil, tar, dirt and barn gum. Minuses - engine stuck ("may run" says the P.O.), no brakes, rear fenders and front bumper dented or split, needs windows, seat and tailgate. But that's what makes if fun, am I right fellas? pix New 52 pix
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | So, Wurlitzer46, do you mind telling me what you paid for this one or give me a good and reasonable figure? I posted an inquiry the other day about the price of a recent "barn find" 1950 3100. The guy was asking $9500.00 and i told him i would give him $3000.00 cash with then hour. He said he paid more than that for the truck and would not take any less than $9500.00. I thanked him and walked away. Based on the feedback I've received, my $3000.00 offer was a reasonable one. You can look at pictures of the 1950 3100 by going to my post titled "Estimated truck Value." Thanks for your input.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | wurlitzer46 - Congrats on the truck!
raleigh58 - at $9500 it would need be a decent restoration that was parked in the barn a month ago. I woulda probably unintentionally laughed at the guy.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | But that's what makes if fun, am I right fellas? pix New 52 pix  | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | I went through the entire 'rusty51' yesterday. Thoroughly enjoyed it! | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Nice truck. I'll bet you will jump right in to it. It looks very complete and quite solid. Congratulations! | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Thanks guys. After two weeks soak in Marvel mystery and PB Blaster, I got the engine to turn with a prybar on the flywheel teeth yesterday. Still stiff and looks like maybe a stuck valve - how hard can I tap on those?
| | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | OK guys, so I have turned the 216 all the way around with flywheel prying. It turns looser now, valves still a little sticky but they all seem to move with no bent pushrods. Collective wisdom please: 1. Is it ok to try to bump it with the starter with the plugs out? 2. Will turning it oil everything ok? If not, how do I need to prime it to be safe? 3. And when should I change out the mix of old oil and PBblaster: now, after a few spins, or after I try to start it?
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I would change the oil, pull the distributor (mark rotor and body posititon first) use a sawed off screwdriver blade in a drill to spin the oil pump til oil comes up to the valve train, reinstall the dizzy and crank it over with the starter,(plugs out) if ok try starting with new plugs/points, condensor, new gas (remote tank jury rigged to the fuel pump), have a fire extinguisher handy though.... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Wurlitzer, please post engine questions in Engine Shop.
Thanks | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | sorry, didnt realize, I started an engine thread, mods please move or delete last few posts if appropriate. Thanks for your post 58gmcnut.
| | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 |  Very Cool. I love it. Good luck with it. Also I think you were smart having it professionally towed. Hope that didn't set you back too much.
Professional Novice
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Nov 2012 Posts: 4 New Guy | | New Guy Joined: Nov 2012 Posts: 4 | so now whats your plan? what modification which you planned for this. I think you have to almost totally rebuild it. Because the condition of the truck is very poor. Wish you best of luck for your truck. Please post the photos as you complete the working on it. Thanks for sharing. | | |
