8 members (cmayna, 2-Ton, 55shaker, Mike Roache, Gdads51, mk72, Opelika Tom, 78buckshot), 102 guests, and 3 robots.
Topics128,185
Posts1,057,203
Members48,465
Hello!
When the previous owner put the heater back in my '53 Chevy 3100, he just ran a hose to it from the engine block, so there's coolant circulating through it all the time. Gets kinda hot in the summer.
From what I understand, there should be a diverter valve that mounts on the inside of the firewall.
Is that the case? If so, is anyone making them.
Also, how do you control the valve? Is there some wire-operated control?
Thanks...
Chris
depends on the grade of heater, the standard heater didn't have any control, but it's a simple fix to get a shut-off from your FLAPS and install it under the hood, available with cable or manual control - example
You can get aftermarket valves that are cable operated and just fit inline with one heater hose. You can also get a heater valve that screws in the water pump and the heater hose connects to it. Check NAPA.
Either will be relatively cheap, effective, and easy to install.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
