| | | Forums66 Topics128,181 Posts1,057,177 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Hello!
When the previous owner put the heater back in my '53 Chevy 3100, he just ran a hose to it from the engine block, so there's coolant circulating through it all the time. Gets kinda hot in the summer.
From what I understand, there should be a diverter valve that mounts on the inside of the firewall.
Is that the case? If so, is anyone making them.
Also, how do you control the valve? Is there some wire-operated control?
Thanks...
Chris | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | depends on the grade of heater, the standard heater didn't have any control, but it's a simple fix to get a shut-off from your FLAPS and install it under the hood, available with cable or manual control - exampleBill | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You can get aftermarket valves that are cable operated and just fit inline with one heater hose. You can also get a heater valve that screws in the water pump and the heater hose connects to it. Check NAPA. Either will be relatively cheap, effective, and easy to install.
Grigg | | |
