| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Question about these leaf springs. They are in a stack of 5, then a spacer, followed by a stack of 7, and then the axle. However, only the bundle of 7 is actually attached to the axle. This seems like overkill for a 1/2 ton truck. Were overload springs an option or is this more than likely aftermarket? Mike http://s1308.photobucket.com/albums/s609/58apachepilot/Leaf%20Springs/ | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, overloads were an option, although it looks like yours has had some leafs added - my 58 3200 has the overloads, but I'd have to look again to see the number in each pack .... if you check the load capacity chart in the shop manual, the extra springs increased the 1/2T GVW from 4000 to 5000, and would usually have come with 16" wheels
Bill | | |
