0 members (), 99 guests, and 3 robots.
Topics128,113
Posts1,056,619
Members48,450
[img]http://community.webshots.com/s/image6/4/34/80/104143480tChrhX_ph.jpg[/img]
This is the back side of a rotary fog light switch. (Sorry it's blurred) It has three wire terminals: the upper right terminal say "Fog"; the upper left says "Bat." The bottom terminal has "T.L." I can't figure what the "T.L." stands for. You can see where the fuse goes. (removed) Thanks for the help....I'm like a deer in headlights (foglights?) when it comes to electrics.
I wrote to the manufacturer who is still in business about this old switch of thiers....but they didn't want to help!
Would that be Tail Lights? I would the tail lights on if I'm using the fog lights. Growing up in the central valley, I know people follow the tail lights and I don't want the low beams on in SOME situations, but always want the tail lights on.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
Russntustin
I have a rotary switch, too. I wired it just like the OEM switch: 54/55 Accessory Fog Lamp Switch
Earlier years are most likely wired in a similar fashion. I like the lighted rotary switch but would like to find an original-style switch.
Tim
So do you suppose the terminal on my switch that is T.L. is for having the tailights come on with the fogs... without having the main headlights/tailights on?
Russntustin,
Yes, it looks like that is what happens (I do not yet have the tail lights installed on my suburban, so I cannot confirm this based on experience).
Tim
Thanks again guys....makes sense now....
Tim, thanks alot for the picture out of your manual. wink
