| | | Forums66 Topics128,115 Posts1,056,626 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89069 12/10/2003 3:32 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | [img] http://community.webshots.com/s/image6/4/34/80/104143480tChrhX_ph.jpg[/img] This is the back side of a rotary fog light switch. (Sorry it's blurred) It has three wire terminals: the upper right terminal say "Fog"; the upper left says "Bat." The bottom terminal has "T.L." I can't figure what the "T.L." stands for. You can see where the fuse goes. (removed) Thanks for the help....I'm like a deer in headlights (foglights?) when it comes to electrics. I wrote to the manufacturer who is still in business about this old switch of thiers....but they didn't want to help! | | |
#89070 12/10/2003 4:53 PM | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | Would that be Tail Lights? I would the tail lights on if I'm using the fog lights. Growing up in the central valley, I know people follow the tail lights and I don't want the low beams on in SOME situations, but always want the tail lights on.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#89071 12/11/2003 4:03 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Russntustin I have a rotary switch, too. I wired it just like the OEM switch: 54/55 Accessory Fog Lamp Switch Earlier years are most likely wired in a similar fashion. I like the lighted rotary switch but would like to find an original-style switch. Tim | | |
#89072 12/11/2003 3:22 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | So do you suppose the terminal on my switch that is T.L. is for having the tailights come on with the fogs... without having the main headlights/tailights on? | | |
#89073 12/11/2003 9:47 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Russntustin,
Yes, it looks like that is what happens (I do not yet have the tail lights installed on my suburban, so I cannot confirm this based on experience).
Tim | | |
#89074 12/12/2003 3:05 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Thanks again guys....makes sense now.... Tim, thanks alot for the picture out of your manual.  | | |
