2 members (Svcattle, baldeagle),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89065 02/27/2004 4:44 AM | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | would someone with a 54 with tail light measure the distance between the mounting bolts coming from the rear of the light housing. My suburban's (clamshell rear) fixture is toast and I need to replace it with one of the aftermarkets supplied by Chevy Duty or Truck Shop. | | |
#89066 02/27/2004 8:52 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | Aloha brother, I'm not sure what distance you mean. Do you mean center to center BETWEEN the bolts to the clam shell? Your door should show that, there has to be holes there? measure from the 3 O'clock side of the hole on the left to the 3 O'clock side of the hole on the right and you got the center to center distance, Mines a '51 but there the same, any confusion and send me a personal email, my Burb is the same and I'll help you out. ALOHA | | |
#89067 02/27/2004 3:34 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | sanderson,
It sounds like you need a new tail light for your clamshell doors and will have to use aftermarket taillamps for a '54 pickup. The distance between posts is 2" on the '54 pickup's taillamps.
The distance is 3 1/4" on the "barn-door" suburban/panel-truck taillamp (but I doubt if this measure is what you want).
Tim | | |
#89068 02/28/2004 3:19 PM | Joined: Jan 2003 Posts: 65 Member | | Member Joined: Jan 2003 Posts: 65 | thanks guys for responding - and yeah the two mounting bolts coming from the rear of the fixture housing are also two inches apart so I guess those aftermarket lights will mount right up to the light/license mechaninsm. Great! | | |
