5 members (Steelonsteel, Hotrod Lincoln, 55shaker, ShopRag, 78buckshot), 100 guests, and 1 robot.
Topics128,035
Posts1,055,552
#89023 10/26/2003 5:45 AM
Hey,
I am streetroding a '66 C10 short step. I have removed the external regulator and have went with a 1 wire alternator. What do I do with the two wire pigtail that would normally go on the alternator and what do I do with the wires that were on the external regulator?? The Temp guage and the ammeter don't register anything when the engine is running. I appreciate any help that you can send.
Be Happy and Live a Good life filled with Love and Happiness.
#89024 10/29/2003 7:30 PM
Check out this link. It should answer your question about the wires.
http://www.classictruckshop.com/one_wire.asp
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
#89025 10/30/2003 4:40 AM
Thanks for the link. However, I still don't know what to do with the old external regulator wires. Do I just cut them off or ? The stock ammeter guage doesn't work but it tests out ok.
#89026 10/30/2003 4:45 AM
What symptom prompts you to say the amp guage isn't working?
#89027 10/30/2003 11:58 PM
Hey,
It doesn't move at all. When you turn the key on or the engine running and you turn on the lights etc. The needle doesn't move.
#89028 10/31/2003 4:13 AM
What happens if you turn on the headlights with the engine NOT running?
#89029 11/01/2003 4:48 PM
Nothing happens. I think that we have gotten away from the original question. What to do with the extra wires since I converted from an externally regulated alternator to a one wire alternator. Certainly some of these wires need to be connected to something or paired up or ?... Surely I am not going to just cut them off or let them dangle..
#89030 11/02/2003 8:43 AM
Are you doing this because your alternator died?
A internal regulated alternator isn't going to turn your truck into a street rod. It's just going to turn it into a truck with a cut up wiring harness.
My suggestion. Summit sells a rebuild kid for your old alternator made by QuickStart that will increase your external reg alt to 105 Amps. But first, do a little reading on this subject.
Autoshop 101
Go to the technical Articles and start reading. I haven't found anything better than this on the web. Don't let the fact that they use Toyota circuits and systems as examples, turn you away. They are for the most part very similar.
Internal Regulator
Has a pictorial wiring diagram. Click "previous" at the bottom of page for more info and diagram with amp gauge.
67-72 wiring
I don't know how close this is to a '66, but it may help.
'67 GMC 3/4 292 4spd
#89031 11/02/2003 8:54 AM
Obviously one or the other type of alternator doesn't make a streetrod. I am not taking this truck back to original. I am modifying it quite a bit. Anyway, I got the answer that I needed from another source.
#89032 11/02/2003 5:57 PM
Is that to say it is now charging the battery at around 14 volts????
#89033 11/03/2003 4:14 PM
I would stay away from the one-wire. See other posts regarding one-wire vs 3-wire alternators, specifically a link posted by Alan Horvath. I suspect one of your unused wires is for the field connection to "energize" the regulator/alternator and likely part of the alternator light circuit. It is possible that the other one was connected to the output, or possibly a "sensor" wire. Is your existing harness in good shape? If not, you may want to re-wire from scratch, then you get to customize your harness for all the stuff you are going to use and where you are going to use it. I think a nicely wired truck adds greatly to its functionality and appearance; I have seen some real "rats nests" at car shows. Lots of nice chrome but the wiring looks like crap.
#89034 11/03/2003 10:11 PM
Did you even bother to read the link I gave you the other day ???
Your answer about the extra wires is on the very first page of the link !!!!!!!!!!!!!!! :p
It reads: You guys who have older cars with external-regulator alternators will have extra wires dangling. No problem--just unplug the wires or remove them.
1950 3100
1971 C-10
1939 Buick Century
#89035 11/04/2003 6:16 AM
Yes, I did read it and I don't have a problem with that. I got the answer that I needed from another guy. You guys can stop posting about this.
