9 members (tclederman, 57 Drifter, baldeagle, Cosmo, Paul_WNC, Bill Hanlon, gswbbc, HandyAndy, 1 invisible), 181 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
#890217 10/18/2012 6:51 AM
About 10:00 PM last night I went to move my C50, which by the way was full of grain. I could not get it out of first gear. No neutral or anything just first. Anyone have any first suggestions before I start ripping the trany out? Trans has the high/low switch for rear.
Richard
circlejacres #890236 10/18/2012 8:44 AM
Shift rail in the transmission is probably stuck.
1952 Chevrolet 3800 pickup
---All pictures---
circlejacres #890269 10/18/2012 10:36 AM
I had a truck that did this. I had to pull the shifter and align the two shift plates that you will see looking down the hole. align the two square shift notches with a large screwdriver and you will be in neutral. You might have to rock the truck if driveline is loaded.
